Help with log
clipto
2,316
5
Oct 8, 2011
Portland, Oregon
Here is my log having a issue at knock when under boost. Towards the end is where the knock is when doing a pull.
How are you running 550cc injectors without adjusting anything in regards to fuel (global % and deadtime, for example)???
Take note of your DTC code that's being thrown. Not an important one, but an issue none the less.
Watch all these videos.
ECMTuning, Inc.
Post back an idle log once you have done all that plus a boost leak test.
Everything is getting signal from the safc for now. I don't know how to take out the safc so I will wait till shop does it and tune it but in the mean time everytime I have to pass someone or go up a hill I hit that boost it spools so fast but I always get about that same amount of knock. That is only about 8psi of boost. Do I need add more fuel?
havent got wideband signal to ecu yet but the wideband read 11:1ish at boost. But your right I will try lean it out see if I get less knock.
I zeroed out the safc and set globals -18.4 and 180 deadtime. Here is the log.
weird I have been driving with that tune for awhile.. I guess I'll take it in ASAP to get tuned it's still pulling fuel trim under boost from safc so it might not be reading 100% correct on link.
