Help! with FPS!
Darkolako
31
Feb 21, 2010
bayamon, Puerto Rico
ok so heres my problem i recently bought a 97 GST today i received my gauges from glowshift i ordered boost, oil press and trans temp.
my question is apparently the person i bought the car from removed the FPS i have done a lot of searches around here google and vfaq onto where to tap my boost gauge and most of them say to the vacum line on the FPS so i dont have the FPS where else i can tap it =( its a Boost/Vacum gauge from glowshift and the first im trying to install I'm a complete noob on wiring and stuff so any help appreciated
theres a vacum line from the fuel rail to the intake manifold can i just cut and tap it there?
That will work. That is where mine is tapped.
Vacuum line from FPR to intake manifold is the easiest place. Make sure to zip tie on all of the lines and connections though. You don't want the FPR line coming off during boost and dropping fuel pressure.
many thanx for your quick replies will do that now and try oil pres and trans temp after
