fps HELP!!
foxracing2216
Jan 27, 2012
berkley, Michigan
im sure this has been posted a million times but theres two solenoids on my 92 dsm. what one is the fps? closer to the passenger side? also what vac lines go to it? im lost. if anyone even knows the color of the wires that are plugged into it that would help alot, i tapped my boost gaug into th line coming off the fpr and now dont know what to do because i dont know what what is my fps... i know its a stupid noob question but i just dont know!!!
Your Fuel Pressure Solenoid will be directly next to your brake booster closer to the driver side. You can also look into deleting those solenoids all together to avoid the hassle. Easy free mod. Just a suggestion.
whats underneath the cruise control setup on the firewall? theres and empty vacuum port there.... also theres 4 vac lines next to the brake booster.... if i elimated those lines, id also need an egr block off plate, which i dont feel like waiting on.. what vacuum hoses go where? both of those soleniiods on my firewall arnt fps correct? im just lost
If you leave your EGR valve solenoid you can remove your FPS lines and just run a line from your FPR to the intake mani (this is the line you tapped into for your boost gauge) the EGR will stay functional.
the other vac lines go to the EVAP canister and purge control valve... all useless, in my opinion.. some others will argue that but its really pointless if you ask me.
check this diagram and read the posts because the diagram can be a little inaccurate when it comes to certain things.
http://www.dsmtuners.com/forums/art...-speed-shop-vacuum-diagram-removal-1g-2g.html
Remember, all this material is available to you with just a couple clicks of a search button
don't get frustrated. There's a lot worse things to deal with, with these cars than the vac lines.
  • Wanted 6 bolt NT water pipe
    • chrisman287
