Help with EVOX 18X8 Fitment
kask
Dec 28, 2010
Buena, New Jersey
Hello everyone,
I'm trying to find an answer I have not had any luck with yet on other forums and I don't want to buy something that will not work for me.
I have tried researching online for fitment of 18x8 wheels on the EVOX but I have no luck finding anyone who has tried it.
The reason I want this specific size is because I found a set of BBS RXs on ebay and they would be perfect for winter use in the snow since I don't have to worry about damaging the finish on my expensive wheels.
It says the offset is +25.
Can anyone help me verify that it will work without potential damage to the wheel bearings?
Someone has mentioned too that it may not clear the calipers since these BBS RXs have a lip and inward concave spokes.
Thanks for your time.
Evo X wheels are 18x8.5 +38 so you shouldn't have any problems with 18x8 +25 wheels, except for the caliper clearance as you mentioned. I would check an evo forum to make sure.
Using this offset calculator: Wheel Offset Calculator
You will have 19mm more inside clearance and about 7mm less outside clearance, but that should still clear your fender lips.
Thanks.
