Help with Drivetrain
04bls84
69
Apr 13, 2010
Lewistown, Pennsylvania
Hello everyone, I am trying to figure out why my car is grindiing when putiing it into gear. I replaced the clutch, TOB, master cylinder, and slave cylinder. I have bench bled the master and gravity bled the master and slave, and also pressure bled them as well. It almost feels like the damn thing has air in it yet but after running a big bottle of dot 3 in it with no air coming out at all I am lost. Never went below min fill in the fluid resevior and no leaks anywhere. If you pump the clutch the pedal is not and does not get hard at all. And if you pump it and then stop it gets more loose as if you just cracked the bleeder valve on the slave. Checked everything and have tried all I can think of except replacing the new parts again. Please Help Me
    • Detail
    • dsmmario
    • Canadian_CD9A
    • my98gsx
