Help With A Dash Light Please
Status
Not open for further replies.
dsmeclipse16psi
44
Jul 17, 2007
roanoke, Virginia
There Is A Light That Stays On In My Dash Now Its On The Right Side Of The Gauges And It Lights Up Yellow And It Looks Like Greek Temple Or A House Or Somthing I Dont Know What This Light Is Help!
I think it's the low coolant light or something along those lines. Check your coolant level just to make sure I may be wrong :coy:
That light is in fact your coolant light. Check and see if it's low on coolant. If not there is a sensor in the bottom of your resevoir you may need to pull it and clean out the resevoir and the sensor using lots of hot water.
This is probably one of the most asked questions here. It has been covered in numerous threads, most of them locked due to it being a FAQ.
Refill your overflow bottle.
Status
