help with a 6 bolt swap in a 2g
There are like a billion 6 bolt swap threads. Just search. I probably made a few of them when I did mine. As far as the wiring, you can just buy a premade cable from magnus or RRE
I'd recommend just pulling a harness out of a car at a junkyard if you're going to change the whole thing. MachV is probably expensive, they are also for sale on ebay quite often. For everything you're looking for just use the search button its been covered a million times.:dsm:
No you don't need the whole harness from another car WTF
You just need to make a cable that goes from the 2g's crank and cam sensor to the 1g CAS. They explain all of that on Magnus and other sites like RRE.com
