Help wiring in A/C slim fan PICS
slikvik
93
3
May 25, 2006
Prosser, Washington
Before anyone tells me to use the search button, well I did and I could not find anything on how to wire in the slim fan on the driver side, a/c fan, for a 1g. They were all for 2g's.
I already know how to wire in the passenger side, main fan, in. Just connect the two wires into the fan, and run the wires to the thermal turn on switch.
My problem came when trying to wire in the a/c fan. I could not figure out what to do with the resistor pack. I don't fully understand how it functions. Should just leave it wired in as is? Or should I cut the resistor pack out and wire the two ends together to short circuit the resistor. (below is a picture of the resistor pack I am talking about).
My goal is to wire in the new slim fans so that they operate 100% like stock. Someone please chime in, thanks in advance for the replies.
I too am in need of help on this same issue. I bought a FAL slim fan that is one piece and has the engine and a/c fan in one unit. I have the same question as the OP. I need to know what to do with the piece that he circled in red. I want it to operate 100% like stock.
Thanks in advance!
The resister pack causes the fan to work at two speeds high/low,i say bypass it cause you don't need the low speed.
