Help Understand Log
LarryJoe
376
15
Feb 10, 2012
Davisville, West Virginia
So I got EvoScan setup on my 2g. I'm running a e316g with a 190 pump which needs rewired and stock injectors. I did a 2nd gear pull and logged it. Throughout my pull I counted up to 24 counts of knock. Even when it wasn't knocking my timing was at 8-10 under boost. I also logged my fuel trims. I just don't understand all of it quite yet. Can someone look over the log and help me understand which I'm getting so much knock? I also noticed my stock injectors hit 110% which I know is bad. I'm set to 9lbs of boost but in the higher rpm's it hits 14lbs and holds it. Thanks for the help.
Bump.
Just a quick clarification.
You are not getting 25 "counts of knock" it looks like the most you are getting is 2 counts, but 24 cumulatively. And yeah, it looks like timing is getting pulled a bit for it.
Looks to me like you need more fuel. What are your plans?
And how is your coolant temp?
Have you set base timing to 5 deg recently?
I'm not an expert but I think these are good first steps.
