help tuning 2g mas with 510s
ryanw2007
May 21, 2007
salem, Oregon
ok well i have evo 3 510s walbro afpr stock 14b and a safc and was wondering with a 2g mas what should i start my base tuning with? or does anyone have a similar set up i can steal?
yea i have checked that out and it only has one base setting for a 1g and its with a 16 g and no fuel upgrades i was looking for a base setup with 510s, walbro 255, afpr, 2g mas and 14b turbo
If you have the stock fuel pump+ FPR Put those back on. Right now with those fuel mods youre going to be extremely rich. 510s+a 2g mas should require very little tuning for like 10-16psi, if you plan on going above that, i believe all you'd need is a 190rewired at that. I've heard that 255 you need the FPR.
Search on what supporting fuel mods you need to run your intended boost level. FYI i popped in some 550cc injectors and a 2g maf for a little bit and i could tune it pretty easy at 14psi ( like within +-20 percent adjustment ). I have a SAFCII + AEM EUGO so that makes it pretty nice
About +15 to +20 for low and +10 to +15 high, then fine tune using your logger. Keep your boost at stock level if you're still on the stock pump.
