help !!!!!!!!!! stupid heater hose.
selmerguy
1,810
23
Nov 14, 2004
Killeen, Texas
so i grounded my battery cable going to the trunk on my top heater hose.(don't ask) and it put A HOLE THE SIZE OF A PENNY IN IT!!!!! can i just replace the hole heater hose and how much will it cost me. do i have to pull the motor? can i patch it some how?
I'm a bit confused with battery cable and trunk and heater hose.
Depending on access, you could just cut the hose and install a splice with clamps or one of those yellow flushing fittings if you have room. You can make a splice from a 3" length of copper pipe or tubing, you can use a tapered socket that will fit inside the copper and give it a smack or so with a wooden block/plastic hammer. Do this to both ends, this will give you a slight flair so it can't slip off under pressure, use the mini clamps for they better conform to the hose radius if you aren't ready to replace the whole hose.
Cheers,
GTM
selmerguy said:
i lied it was the egr hose and i bought one from the dealership for 60+ bucks. thanks though
Gosh, I would have thought when no water came out that would have been a clue. Still for $3 you could have fixed it.
Try to be more accurate when describing problems for obviously it makes a big difference when people try to help you.
Cheers,
GTM
selmerguy said:
should have been a clue but i was to pissed to think. and i didn't think the egr hose was that big. how would i have fixed it for 3 bucks?
Had you gone to the hardware store and bought a short length of copper pipe, cut the hose at the damaged spot and done what I suggested... $3-$5 at best.
  • For sale 2g 2G 7 Bolt Lower Timing Cover
    2G 7 Bolt Lower Timing Cover $80 + shipping & paypal fees* there are a few flaws ( pictured )...
  • For sale 2g 2G Manual Shifter Cables ( including NEW bronze bushings )
    2G Manual Shifter Cables $90 + shipping & paypal fees* I will be including NEW bronze bushings...
  • For sale 4G63 Race parts.
    It is the time to make room to improve the DSM, getting rid of some extra parts I no longer...
    • GST2012GSX
  • For sale 1g 1g turbo oil feeds
    1g TD05 oil feeds. Found another box. Have 15 feeds. Have no return lines left. Been running...
  • For sale 2g 29 tooth auto speedo
    29 tooth 2g auto speedo. Good condition. Price is shipped. Message 702-741-6987
