InfiniteGSX
- 3,182
- 16
- Dec 10, 2002
Tijeras,
New Mexico
Ok, A little story. My car dyno'ed at 456whp and as I left the dyno I was t boned. So I picked up a new shell for a grand, in mint condition. It needed a new harness, So I transplanted my motor, trans, tc, wheels, suspension, and front car harness into the new car. I started it up and it was chugging. Then I found a hole in the coupler on the intake.... so I figured that was it. Fixed it. Problem is still there. Also noticed now, when I hit the brake, it almost kills the power completely. Voltage is like 12.5v not running on a perfect battery and dropps down to like 8v when I hit the brakes. I start it up and I can almost kill car by touching the brakes or trying to roll down the windows. And its like running on 1 cylinder, or 2.
When I pulled the motor, it was running fine and flawless. And actually very reliable. I know it has to be something voltage related but I cannot find anything wrong. All fuses are good. Relays should be good because they came from the old car.
I flipped over the CAS like 50k times thinking something was off.... but that isn't it. I don't know what else to do, except pull the harness off and reinstall it.
and the battery light goes off and the alternator puts out a perfect 13.52v and stays there.
, nothing! I know the coil packs are working... but doesn't seem like they are fireing the spark plugs.... maybe? head is perfectly grounded.... so that can't be the issue. Next I guess is to take the plugs out and test the plugs with the coil packs.
