gingerbredman00
- 316
- 1
- Jul 9, 2009
TULSA,
Oklahoma
My reverse light stays on no matter which gear i'm in.
the plug is connected, and the reverse light switch worked perfectly fine in my last transmission..
I'm loading a video as we speak, the grind in the video is because I didn't make the wheels stop spinning before going to reverse..
I guess it would help if I told you guys im almost dont with my AWD conversion.
I have installed an AWD transmission, transfer case, driveshaft. Also a new sprung 6 puck clutch with an as close to stock as possible pressure plate to work with the clutch.
Yes I had the flywheel resurfaced.
All I have left is the drivers side half shaft, and a new tie rod end for the passenger side, (my fault) oh and more fluid in the transmission. and i'll be good to go! slowly for the next 500 or so miles
YouTube - goofy DSM reverse lights
but it seems to be one of the more interesting subjects when workin on my car..
