help please no spark 1-4 coil when hot NOT ICM
tommy
Dec 27, 2009
Denver, Colorado
can someone describe to me how to put a jumper wire from ecu to 1-4 coil i really need to get this fixed and cant figure out wats goin on i have anoter post but no one has replied to it can a 1g cam sensor be my problem? it was used and its not in the best condition
I don't have link but its not throwin random misfire code its throwin p 0340 code for cam circuit and its only throwin it when 1 and 4 coil stops working
I followed luv2rallye instructions for testing transistors and it was good! I borrowed one from a friends car that is known good and still had the same problem
Is power transistor the same as ignition control module? The 8 pin connector missing number 4 pin? On top of intake behind fuel rail? That's what I tested
