sethpatch
- 89
- 1
- Jan 19, 2010
harrodsburg,
Kentucky
Ok so I'm finally getting close to that time where I need to finish my fuel system up on my car and get it ready for my jmf topmount manifold to be in the mail in the next few weeks. I'm trying to pick my injectors and fuel pump since I know my old setup from my big 16g won't be enough for my goals. I been a lurker on here for years but I don't post much.
My car is a 98 gsx, I have:
Motor:
2.3l 6 bolt bored .20 over
Ross piston eagle rods 9:1 compression
all ARP hardware
Head:
6 bolt head
1mm oversized Ferra valve freshly rebuilt
BC 280 cams
BC springs
BC adjustable cam gears
ARP head studs with stock MLS gasket
Fuel:
-8an feed, -6 return all steel braided
FIC fuel rail
Aeromotive AFPR
Walbro 255 fuel pump
PTE 1200cc injectors
The fuel hats have had new lines brazed on them and the siphon has been ported out
Turbo:
Holset hx40 freshly rebuilt 19cm exhaust housing
JMF Fabrication divided t4 top mount turbo manifold
Twin 40 mm Synapse waste gates
Drivetrain:
Mostly stock for now with solid sub frame bushings and all new poly suspension bushings, soon to have evo brakes, 6 puck un-sprung act clutch with act2900 pressure plate and act flywheel
I know my Walbro 255 will not be enough fuel pump, so I have been looking at the new Walbro 450lph. I am trying to figure out right now if that single fuel pump will be enough to reach over 700hp, I want to do all this once and be done with it, but not get to out of hand like a mechanical pump. I know my injectors will be enough to maybe get me around 400-450 with methanol injection, but I was looking at maybe some 2160's or bigger.
All advice is appreciated.
Motor:
all ARP hardware
Head:
6 bolt head
BC 280 cams
BC springs
Fuel:
FIC fuel rail
Aeromotive AFPR
Turbo:
Drivetrain:
. The turbo is a 8 blade hx40 with a 19cm compressor cover, it's completely stock and freshly rebuilt from cummins
. honestly right now I was looking arounf 25 pounds of boost, but I gotta be easy on my drivetrain till i build it up, it's on the list of things to do. I have actually been looking at a jacks transmission tranny or shep, and a upgraded transfer case with a welded center diff and upgraded rear end housing. I appreciate your concerns but I been doing my homework on this build. This car is gonna be more of a street warrior for now, so I'm not gonna beat the hell out it till I get the drivetrain upgraded.
