Help... No Boost
dragracer
Feb 27, 2005
Cedar Rapids, Iowa
Car was running fine , boosting up awsome, all of a sudden NO BOOST at all, played with the boost controller, nothing, can not find any vacum leaks, you can here the turbo working great, Has a HRC 20, what could it be. Please help.....
this is kind of dumb but did you check your turbo induction? and did you check turbo for shaft play. did you check your manifold maybe it has a gash or leaking someplace does the car smoke?
It is definitley a big boost leak. Do a boost leak test. I had the same problem and it turned out my gasket on my intake manifold was bad. Thus no boost :toobad:
1. Tell us more about what the boost gauge is telling you, no boost is very general, need more info.
2. Check the turbo for in and out, side to side shaft play, make sure the turbine spins freely. Check the LICP and IC for oil.
3. Make sure the actuator arm has not popped off the wastegate lever.
Good luck.
  • For sale 1g 1g turbo oil feeds
    1g TD05 oil feeds. Found another box. Have 15 feeds. Have no return lines left. Been running...
  • For sale 2g 29 tooth auto speedo
    29 tooth 2g auto speedo. Good condition. Price is shipped. Message 702-741-6987
  • For sale 4G63 91 to 96 Auto T Case
    91 to 96 Auto T Case $195 + shipping & paypal feesYou must be registered to see element.You...
  • For sale Turbosmart Ultragate 38mm Gen V
    Brand new in box 2bolt flange waste gate, I no longer need this. Price is shipped in the states...
    • GST2012GSX
