Help needed with stroker 4g63
Powerboarder
73
Jun 18, 2003
Florida
building up a stroker 4g63, and I have run into a roadblock. I have the correct wiseco pistons, but the 2.4L crank and bearings I have will not fit in my block. The main thrust bearing is too narrow. The crank is from a 1995 galant 2.4 4g64. I guess this is the incorrect crank? What is the crank I need to pull off this buildup? I am starting with a 6 bolt 1992 4g63 from my talon. I need the year make and model of the car that this crank comes in. Please help.
talked with a guy at roadrace engineering and he said that I need a crank from a 6bolt truck or van can anyone attest for this.
can someone sticky this? clearly people cant find the search button, so just put this on the top so no new threads will be started weekly about this. tia.
95 galant had a 4g64 7 bolt motor. it is not a 6 botl crank. ive looked at quite a few and after early 90's there was no 6-botl 64.
SBR has 64 6-bolt cranks for liek $350 with bearings. get oen of them and it will drop rightin but you also have to releive the main caps on the block or your rod will nails it. it gets slight clearencing and will not hurt the stregnth of the block
  • Wanted 2g Test Pipe/Straight Pipe
    Just wondering if anyone has a test pipe that replaces the stock cat for sale. No preference for...
    • DankYeezy
  • Wanted 4G63 Ecu 1g 1991-1994 Eprom socketed
    Wtb Ecu 1g 1991-1994 Eprom socketed in good working condition!
    • niki_talon
  • For sale 4G63 Stainless T3 header w/38mm wastegate flange
    Same header you can get for $230 on eBay. Like new, only ran for 10min or so. Price is shipped...
    • GRNDSM
    • dsmmario
