Help me make this work
apedog
158
May 6, 2009
Lewisberry, Pennsylvania
I made a homemade boost controller with the ball and spring thing.
How do I hook it up so it actually works.
Everytime I try to hook it up right before its only boosing to 7/8. Now when I hook my controller to ANYTHING it boosts to 14/x. I tried turning the screw the whole way back and it still does it.
I need a step by step tutorial here because somethings up
Thanks
Please go by the picture so I know what to do
http://s56.photobucket.com/albums/g186/cletus1234/?action=view&current=P1030280.jpg
On the left is the BCS. One nipple to the wastegate but the hose is teed off to the hose that goes right above the turbo on that pipe nipple. The other to the intake.
dam thats long... LOL mine is alot smaller but other than that... if you want to turn the boost down you have to dont connect the the line to the bcs...... hook one side to the wastegate and the other to to your j pipe or turbo nipple...!!!
Honestly, you're better off getting a cheap MBC. I'd hate for your homemade boost controller to malfunction and have it not open your wastegate and blow your engine.
Grab a Joe P. MBC from BoostController.com LLC - America's Source for High quality turbo boost controllers, silicone hose, and more performance products - 877-836-6155- precision boost control. Turbosmart Warehouse Distributor.
i gotta say... if its built properly it will be reliable..... mine holds steady at 25psi... its alot cheaper yet you have enough time to buy a good one...!!!!
