Can I make this intercooler work? Picture inside
Ehhh looks to short like the radiator would be in the way. But maybe with some modifications and custom ic piping it "might" work.
looks like piping would run right through the rad... take it to a welding shop and get them to weld the inlet/outlet out the sides and weld the existing hols shut and you could use that no prob..
Like "noV8undrDIShood" said take it to a welding shop and have them put the inlet and outlet on the ends of the tanks. When u get it back make sure you test it for leaks.
For the amount of money you would have to spend on getting custom end tanks made and custom piping, you could just save up and buy a cheaper kit from one of the supporting vendors on here. Just do a little browsing and I'm sure you'll find a good buy. Good luck!
the tigging would be really the only expensive part, and you don't need custom end tanks to be made. Cut the inlet/oulet off, cut a coin to weld those holes shut, take a hole saw and cut two holes on outside of the tanks and get two peices of pipe welded.. NOT difficult. Intercooler piping is not expensive if you do it yourself, get a cheap universal piping kit off ebay and got to town
Too bad your in Pennsylvania, or i'd weld the end tanks for you! Get a Honda half sized rad and mount the inter-cooler on one side, i think that would cost less than putting the endtanks on the sides, Plus the intercooler piping would be alot easier routed. Good luck!
