marsh63
- 517
- 0
- Oct 15, 2007
richland,
Washington
i just got this new 1990 eagle talon non turbo as my daily driver. the car has 150 lbs of compression in each cylinder. the timing is dead on.
when i got it the car will not go above 4k and has a 500 rpm idle surge. while sittin still with no load i can rev the car sometimes past 4k. it feels like i have a rev limiter.
so far i have taken from my other talon the had non of these problems.
alternator.
transistor
i tested the car with my coil from my good talon
the idle thing on the tb that has the one wire going to it
things i did to try other possible things
i cleaned everything
checked the mass air flow sensor
new O2 sensor
new wires
new oil
checked for vacuum leaks.
blocked off egr since it was stuck open when i got the car
i checked the ecu and non of the caps are leaking.
so right no i am completely stumped. so if anyone has anyother sugestions please tell me.
oh when i unplug the tps and the idle thing the car will not have idle surge but it still wont rev. when i unplug the iac the car will sometimes do the same but most of the time die.
please tell me something!!! will the tb parts from a turbo talon work on a n/t?
only way how to get above 4000 rpm when there is load and it only works if you do it this way for the car is to go in thrid and then drop into 2nd once your at about 3600 rpms in 3rd. and then i can run it all the way to redline. (i know this is not good for the car).
alternator.
transistor
new O2 sensor
new wires
new oil
