HELP, Irregular CEL and RPM drop.
insanewayne
317
May 18, 2004
Ladysmith,
Ok, 91 TSi AWD. Car wouldn't start, it was the caps. Got them replaced, they had leaked on the board, lifted a traces, my buddy repaired the trace with a wire and installed the new caps and cleaned the board.
Starts everytime, so that problem is fixed. Before when it wouldn't start, it would turn over, sputter a few times. Then I would turn the key to the off position, wait for the Relay to click off, then the second relay aruond 8 -10 seconds later. Then it would usually fire, then I guess it got bad enough that I just wouldn't fire no matter what I did.
Ok, so now randomly, I'll be going down the road and when I let the throttle drop, it will sometime drop way down to like 500 rpm, the CEL will come on, and during this time I can still rev the engine, but it sounds like its running on 2-3 cylinders (only way I can describe it...like an airy bogging.) I can give it throttle, it struggles, then once it hits like 2-2500 rpms, the CEL goes away and it returns to normal.
No patterns noticed, completely random.
HELP!!!
Thanks,
Wayne
Thanks man, but I don't think my problem fall into those categories, I know all about idle surge etc...
Thanks,
Wayne
I'd suggest reading the code to see what the ECU thinks is wrong before doing anything else.
It might still be a ECU problems but knowing what part of the ECU is acting up helps repair it.
Or you could actually have a problem with the car.
Steve
