2G Help Identifying a Harness
eltoshan
51
Oct 26, 2009
Pittsburgh, Pennsylvania
Can someone help me identify what this harness in the center console of my 95 awd is? It is the black 4 pin harness circled. Is it the B-33 (ABS G Sensor)? If so, where does it plug into?
If it is not the ABS G Sensor, might it be related to my instrument cluster not having all of its lights on?
If you're trying to figure out why your lights in your cluster aren't on, I would take it out and check all the light bulbs that are there. I've had to change out about 5 or so. Some you can definately tell are bad and others you have to look at them really good because they'll have a really small break in the filamint.
I'll check the bulbs in the back of the dash, but I think I probably have more problems than just that.
When I plug in the scangauge, my speedometer stops working and another gauge cluster light shuts off. Does anyone know if that plug I have in the first post should be plugged into anything? I can't find the other side of the harness under the dash.
There's also a white 14 pin connector to the right of the glove compartment that I don't have plugged in, which I'm assuming is B-26, the automatic compressor-ecm (Non-turbo). Is that supposed to exist in a turbo wiring harness?
