HELP! DSM Wont move , locked.
miliman13
2,394
614
Jan 1, 2011
tampa, Florida
i had a tow truck come for the car to move it to a friends house, And it wouldn't roll
forward. like if it was in gear. but it was in neutral , i moved the shifter around and
got in the car and held the clutch pedal down. and it still locked up, like if it was in
gear when the tow pulled forward. "" i could see the cams rotating as the car was
being dragged up the ramp"". what could cause this ? . also i just did a engine
swap. did i miss something ? i was thinking maybe the slave/ or the master . but
really don't know.. ALSO starter wont make attempt to start so i believe those two
issues are connected.. Thanks guys
:confused:
if it dose not move the master slave could be bad and leaking or also it could be your clutch master cylinder leaking. if they are it is bad air can get into your whole clutch system.
You have a broken 3-4 shift rail. It is stuck in 3rd or 4th gear and if you put it into 1st or reverse, you are in 2 gears at once, which means the car won't move. If you leave it in neutral, you are in 3rd or 4th at all times. The trans needs to be torn down and THIS replaced.
Note that shift rails usually don't break for no reason. The synchros are most likely grinding causing the rail to break. People should never force the trans into gear, especially when it is grinding.
Good luck!
Jack
  • Wanted 4G63 WTB Evo 560cc injectors or 450cc
    Im looking to pick up a set of evo 560cc injectors or possibly a set of 450cc injectors if the...
    • eclipsemf
  • Wanted 1g Looking for pn MB522081
    Looking for a factory 1g double din radio bezel pn MB522081
    • Kgilis
  • For sale 2g 2g Talon drivers side airbag
    Drivers side 95-98 Talon airbag. Excellent condition. Can ship UPS ground. Message...
  • For sale 2g 2g Talon tail lights.
    Pair of 2g OEM Talon tails. Decent condition. Not show quality. Right has a section on bottom...
  • Wanted [WTB] Hyundai 4g63 inner valve cover bolts
    Looking to source inner valve cover bolts for a Hyundai 4g63 valve cover
    • TheDude236
