HELP! Did i buy the wrong Main bearings?!?!?
rennat
Nov 12, 2006
Tracy, California
I just got my order in from Extremepsi.com, i ordered ACL Race Series bearings for my Mains, and Rods, the Rods look to be ok, but im a little confused on the mains. I thought they had a little flange that kind of helped hold them onto the bearing seat? Am i wrong? I'll include pictures of the ones i received, the part number from ACL is 5M1219H, which seem to check out ok. but im still confused. Do I still need to order some parts?!?!?
-Tanner
ps. the pictures are taking forever to upload, so i'll post those once they are done.
Here are the pictures of the main bearings.
Are you referring to the THRUST bearing? If so, that part # you have is for the later model (97+) 4G63 with thrust washers . . . the earlier 7bolt models had flanged thrust bearings like in the pic. That's a different part # (5M1186H). Check out store.partsdinosaur.com
Can I ask how many thrust washers I need when i have a '97+ Gs-t? :)
I just got a set of 2 halves of thrust bearing and the same set of bearings you have posted on top. W/O thrustbearing edge on the main bearing.
Do I need more thrust bearing halves than the 2 I got already? :)
John
