Spyder Help Cruise Control won't work?
rixcidia
280
Dec 5, 2007
Somewhere in BC,
hey guys i have an issue my CC used to work when i had a 6 bolt engine installed but when the motor died i bought a normal 2G 7 bolt Motor and had the shop install it for me ever since that my cc no longer works i dont know what it could possibly be the shop says they dont know too and i do not know where to start i really want this fixed when I hit the cruise control lever as im driving the green "Cruise" comes on the dash but noting happens when i let off the gas the car just slows down and wont engage the speed or anything please let me know what you guys think or if i need to buy a new cc Motor? thanks. :hmm:
Rix
First check to see if the module thats bolted to the passenger strut tower is plugged in. While you are there check the fuse to see if its blown. You can also check the switch on the clutch pedal (the lower switch, there are 2) it might be out of adjustment or the rubber stop is simply worn out.
