Help: car shuts off?
Slo Swag
Mar 25, 2012
clarksville, Tennessee
Please help if you can. So if I drive normal the car is ok. But if I try to hit it in first or second the cars power flickers on and off about 5 times. Sometimes the car will stay on and sometimes it wont. So what can it be?
Yes I mean everything and I mean everything shuts off. I'll try the negative battery terminal. The cable was short to I rerouted the cable to the throttle body in between the braket for the cas.
The main ground is from the battery negative to the throttle body. It was lower down
on the block
