HELP car not making power
99FWD1G
Mar 3, 2008
Freehold, New Jersey
I just got my car tuned at a local tune shop and it seems weird that my car only made 265 to the wheels @20psi of boost with the current set-up....
FP 18G
o2 Ported Housing
FIC 550CC
Injen Intake
ETS 7" FMIC
SAFC Neo
Comp Cams
RRE DP
RRE High Flow Cat
Apexi N1
Can someone help me because im sure this car should be making way more than 300+..could it be my ecu
I have no idea the tuner didnt say anything about codes just that the ecu was pulling the timing because there was knock in the motor...i just think im going to have to get a dsmlink instead of the afc
The only component that stands out to me is your injector size, and according to RC Fuel Injection (RC Fuel Injection), 550CC injectors are only expected to make about 305 BHP (274 WHP assuming a 10% loss from the crank to the wheels).
That HP number was obtained using:
B.S.F.C. = 0.55
# of Injectors = 4
Max IDC = 0.80
I personally don't have a lot of experience with the actual horsepower that 550CC injectors can support, but math usually gives pretty good estimates.
if i remember right i think that if you run too lean, that could create knock. but i would upgrade inj. if i was you. it would be a good first step.
Thanks guys for trying to help out...i found out that the compression in my motor was shot!!...so i ordered new internals and rebuilding the heads...so I think that will do the trick
