help ASAP
JonathanPhelps
Mar 8, 2005
Stow, Ohio
This is sorta complex... I just hit 120k miles so i did a full tune-up. I changed out my timing belt, water pump, thermostat, all my drive belts, plugs and wires. I got everything back together and it has horribly irregular idle now, and occasionally stalls out. It's sounds like it's missing sometimes too. I went back and regapped my spark plugs and that helped some. I gapped them to the original .28-.31 gap as recommended according to the manufacturer. It would barely stay on at that point. I examined my old plugs and they were gapped at .41. So I set my new plugs to the .41 but it didn't fix the problem entirely.
I also noticed some weird things when i did the job too. The crankshaft it missing it's timing mark for TDC so i just made sure to set it up just like it was. I checked the cylinder when the plugs were our and everything appeared to be in order. Now i am getting some squeel from 1 of my drivebelts. I think that i might have it a little tight. Any ideas what i can do to fix the problems?
I was also thinking since the car appears that at one point it was heavily modded i might be up against a diff compression ratio inside the block. thus the difference in gapping the plugs. Let me know if you guys have any light you can shed on my situation.
Sincerely thankful.
well im not sure about the low idle, perhaps you have a bad head gasket or bad piston rings. but are you positive that the crankshaft sprocket is missing the timing mark? its kinda hard not to have a triangular chunk of metal missing from the factory.
