help 95 esi 5 speed tranny interchangeable?
You can take the transmissions from the 95-99 eclipse rs/gs for sure, no problems. As for others I'm not sure of.
As mentioned, 95-99 NT Talon and Eclipse.
As well, 95-05 Neon, 95-99 4cyl Dodge Avenger and 95-99 4cyl Chrysler Sebring.
Cloud car trannies won't work, but the Avenger and Sebring are not Cloud cars.
1st gen Neon transmissions have a cable actuated clutch than needs to be swapped for your hydraulic setup (or vise-versa, I suppose) and the VSS needs to be swapped. They otherwise fit just fine. 2nd gen Neons have the hydraulic clutch setup already.
http://www.dsmtuners.com/forums/dsm...stions/297962-neon-tranny-3-55-swap-info.html
The Avenger and Sebring transmissions are identical to the 2gnt tranny and work without modification.
