Help 92 eclipse gs barely running.
fast_tsi6
Jun 13, 2005
Knoxville, Iowa
Hey everyone,
I am having a problem with my 1992 Eclipse GS. It will not start, unless i hold the throttle down, and when it does run, it stutters and bogs very badley, also it will not idle at all, it just keeps dieing. I come from a Honda background and know very little about Eclipses, so if anyone could let me know what to check etc. I would very much appriciate it. Thanks.
wow this site is very helpful, only one person has an idea about what could be wrong, these "wisemen" must not know shit i suppose
No body replied because evidently, you didnt do any research before you started posting.
As stated, check coils, power tr, fuel pump, cam timing, and ignition timing. Also, check the ecu for leaking caps, replace plugs, wires, and fuel filter. Go to vfaq.com and learn something about your car.
