Musashi450
- 94
- 0
- Jan 3, 2003
Champaign,
Illinois
Hey guys,
Ok so I've searched around A LOT and haven't been able to come up with a definitive solution for my problem. As the title states, I crank the car and it doesn't start.
I'm in the process of rebuilding my engine and after getting it all in and put together it was starting up (with a little hesitation at times) but it would start up none the less. I have an optima red top and I accidently left the lights on in the car so I left it charging overnight on a 2Amp charge, ever since then no start.
Thinking oh I messed up the battery, got it checked at Autozone and they said it was fine.
I just did a compression check and got 150-150-140-140 so that looks good. Needed to replace the starter and I did but that didn't help anything. Also had the alternator checked and that was fine.
Now the strange thing is that, while I'm cranking (I have a analog voltage gauge) I see it just drop which I don't recall it doing before. When I mean drop it just loses all voltage going to this circuit.
I know I'm getting fuel because the FPR gauge reads 45psi while cranking. Thinking maybe an injector was dirty I looked for fuel while doing the compression check and fuel was getting into the cylinders fine.
Also pulled the computer (I know its usually a 1G thing with the computer going bad, but figured I'd check) and it looks great. I also know that its getting spark because I shocked the shit out of myself while checking.
The only thing that I can think of maybe is that the battery load test wasn't very reflective of what my battery is actually doing, or maybe I'm not getting enough voltage to the coil, hence not a strong enough spark (Sure did hurt though). Plugs and wires are new however so maybe something in the coil?!
Something is grounding out but I don't know where!? Any help is appreciated guys. Damnit I'm gonna tackle this one. Thanks a bunch!
Edit: Also I've checked all the fuses except for the two 10A up near the ignition column but because it turns over, I doubt this is it.
guys this is driving me crazy!?! Apparently I have spark on all four plugs and its nice and blue. Then I put it back in and reattached the computer and it turned over for a sec!!!! Ever since then I've kept trying but then it started just turning over for a little bit and dying. Now its back to where I started!
For a bit it just started clicking when I went to turn it over but soon enough it started cranking again. WTF is wrong with this damn car! If I have fuel and spark that rules out several sensors right?
One thing that I'm confused about is when am I suppose to hear my fuel pump turn on because I only hear it turn on when I crank. Can someone please school me in the MPI relay because now I'm thinking maybe its that?
Ah I'm at a loss now someone please help!
guys this is driving me crazy!?! Apparently I have spark on all four plugs and its nice and blue. Then I put it back in and reattached the computer and it turned over for a sec!!!! Ever since then I've kept trying but then it started just turning over for a little bit and dying. Now its back to where I started!For a bit it just started clicking when I went to turn it over but soon enough it started cranking again. WTF is wrong with this damn car! If I have fuel and spark that rules out several sensors right?
