Hello, I'm looking at a 92 eagle talon tomorrow.
vinniepearl
Sep 9, 2008
Davenport, Iowa
Hello, I'm going to look at a 1992 eagle talon tomorrow. I'm wondering what sort of things I should look for that would be bad? I'm not familiar with these cars. I know a pretty good amount about engines but are there any specific common problems I should search for? Also is the 92 a 6 bolt crank?
I'll also do some searching. Any advice would be much appreciated.
Thanks,
Tim
check for the basics. burning oil, pushing coolent, fluid leaks, check to see how the timing belt looks. drive it for sure! see how it goes through the gears.. and yes the early 92's were 6bolts
you can tell if it has a 6 bolt by looking at or feeling the oil pan...on the passenger side of the pan you should feel what seems like a dent if its a 6 bolt...7 bolt actually pops outwards in the same location...someone correct me if I am wrong but im sure thats right
also just make sure there arent any hanging wires or missing components from the engine bay...if it looks like someone hacked it up personally i would stay away from it
when you get it tomorrow take some pictures so we can all see what you are working with
I thought the dent was on the drivers side at least thats where the dent is on mine.
