Hearing a clicking sound when pushing in clutch
nicknorth11
663
7
Feb 9, 2005
Grand Blanc, Michigan
There's a clicking sound coming from the engine bay every time I push in the clutch. Also, and I don't know if this is related or not, the clutch needs to be bled and re-adjusted, as it changes its level of engagement constantly. Any thoughts as to what could be causing this? If you need any more info. that I'm not thinking of, just say the word.
Thanks
I would say to do the bleed job. If you know somethings not right then knock it out before you ask the question. If the problem is still there then it could be your clutch slave or master cylinders. They're hydrolic and have some moving parts. Other than that it could have something to to with the clutch.
Good luck bro!
I can't bleed it yet since I don't have anyone to help me with it right now. I actually don't think it's the master or slave, as they were both replaced in the last few years and I don't they would make a constant clicking sound anyway.
Throw out bearing...I installed a brand spankin new OEM TOB with the car in neutral car is quiet as can be...puch clutch in...rattling...hum...either way I'm driving it that way til something decides to blow out I guess....
I really don't feel like yanking this damn 2g tranny again...1 time is 1 time too many LOL
1g's I'll yank it for fun LOL
I already bought one and tried it. It didn't work well at all. Thanks anyway.
Any other ideas about the clicking sound? Anyone?
Did you open the bleeder screw too far? It'll actually let air back in as you let the clutch back out. I've been using that for 10+ years and never had any trouble. You can also use a jar/container with some brake fluid in it (1 inch or so) and a length of hose. Just submerse the hose in the container, in the fluid. That's key, the end of hose in the container must be submerged in the fluid. This is true with the item you bought. It needs to be filled with some fluid before you start.
Your change in the release point would lead me to believe that you've got the M/C misadjusted inside the car. Sounds like you are right at the point for it being in cut-off. At any time the clutch pedal is fully released, you should be able to push the S/C rod into the body of the S/C.
As for your clicking... only things I can think of are these:
Release bearing going bad. If you had the pedal adjusted wrong and it was in cut-off loading the bearing all the time,it doesn't take long for it to go bad. I've done this inadvertantly on my 1g when I put a 2600 in and the TB was shot within 10K miles because it was loaded and being spun every time it was running.
Lack of lubrication. The quill, the release bearing rides on, may be dry or lacking lube causing binding/metal on metal wear.
Misadjustment. If you do have the pedal misadjusted. With in cut-off, you can get pump-up. And when you have pump-up, the hydaulic system between the M/C and S/C ends up with more fluid in it than it's designed to have. A resultant of this, is the resting point of the release lever sticking out of the trans. It will be biased to the pass side and not centered in the window cut in the case. The end result is when you fully stroke the pedal it will hit other edge of the window. So, you'd be over stroking your clutch which could also be causing noise. Hard to say what exactly your clutch PP will do if you overstroke it. I've heard some click, but they all will act different.
I know this is an old thread but i am having a similar issue. Lately i have been hearing a clicking noise from the engine bay while pressing in the clutch. It has recently gotten worse and does it at idle with clutch disengauged. Thing is that the clicking sound can only be heard from the drivers side? I wanna say its my throw out bearing but wouldnt i hear it from the other side? Thanks for any help
Yeah I've narrowed it down to coming from the pulley end of the crank. Idk if it's the harmonic dampener or not. Wouldn't the harmonic dampener constantly make a noise instead of changing pitch with the clutch engaged? Also I'm pretty sure its my TOB, my master cylinder went out on me today and i know an improperly adjusted clutch would cause the TOB to constantly catch because of it not fully disengaging. Thing thats got me confused is that the sound isn't coming from the tranny only pulley. :hmm:
Yeah, you would hear it from anywhere. Can you hear it from the engine bay itself? If so, can you narrow down where it's coming from?
It would help others if you posted your findings/solution from your issue.
Ah yes, please do, my spyder have recently started having the same problem. Less than 5k on oem master and slave, less than 1k on rebuilt trans with new oem TOB, fork, pivot ball etc...
Well mine turned out to be caused by my trigger plate hitting the crank sensor. Caused by thrust bearing failure, crank end play was bad. Could move it by hand and hear it clunk. CHECK THAT CRANK END PLAY JUST TO BE SAFE! Luckily i caught mine just in time
I don't know if the trigger plate is hitting my cps but it looks like it. Check out these pictures, does it look right?
<a href="http://www.flickr.com/photos/58173320@N00/5835322716/" title="DSC_0432 by naisaechao, on Flickr"><img src="http://farm4.static.flickr.com/3270/5835322716_b4c3e94e63.jpg" width="500" height="333" alt="DSC_0432"></a>
<a href="http://www.flickr.com/photos/58173320@N00/5835322512/" title="DSC_0427 by naisaechao, on Flickr"><img src="http://farm4.static.flickr.com/3178/5835322512_ce47d72e29.jpg" width="500" height="333" alt="DSC_0427"></a>
<a href="http://www.flickr.com/photos/58173320@N00/5834769789/" title="DSC_0426 by naisaechao, on Flickr"><img src="http://farm4.static.flickr.com/3347/5834769789_19dce89aa4.jpg" width="500" height="333" alt="DSC_0426"></a>
<a href="http://www.flickr.com/photos/58173320@N00/5835322002/" title="DSC_0424 by naisaechao, on Flickr"><img src="http://farm6.static.flickr.com/5314/5835322002_396e6b5402.jpg" width="500" height="333" alt="DSC_0424"></a>
Update: I am still having this problem. I have done an awd swap and have a new throw out bearing, and I made sure everything was well greased before installation. I've also adjusted my master cylinder rod and installed an ss line between the hard line and slave. None of these things worked. I just bought a new slave cylinder and plan to install it as soon as I get a chance. Unfortunately, I still don't have someone to help me with bleeding the system, so it may take a while to find a volunteer on the local forum. If that doesn't work, I'll replace the master.
