Clicking in the clutch or transsmission
Dr3wStx
145
Jul 29, 2004
97 AWD
I have a clicking noise in first and second gear only under accelleration it has been going on for over 8 months now.
It sounds like its coming from the clutch/tranny area. It's a metallic clicking that increases in sound and frequency the faster I go.
Driving slowly in reverse will "sometimes" produce a a much louder and slower grinding/whineing noise, almost like something metal is spinning and being pushed against something that isnt moving. Sometimes I can feel the clicking through the gear shifter. Not always.
The clicks go away between shifts and any gear above second is fine.
Clutch still grabs well, shifting gears not a problem. It's not the CV shafts, wheel bearings, or the brakes.
I searched around and i'm leaning towards the TOB, but im not so sure because it doesn't make any noise when the clutch is pushed in or in neutral.
ideas?
My NT is doing the same thing but in Neutral it makes the same noise. I am leaning towards the TOB since I too can push in on the clutch and the noise goes away. I just have to wait and hope it doesn't go out before I get my new clutch kit.
Im leaning towards throw out bearing. But I could be wrong. When my civic had a similar problem. I switch TOB and it went away. If you step on the clutch and the noise goes away. Could be the TOB. Good luck!
Man I feel sorry for dsm tranny problem people. It's a hassle. I'm myself is a victim right now and Jack from Jack's trans. is trying to help me.
