Headlight switch
AKeclipseGSX
138
Jul 10, 2010
Chugiak, Alaska
So I put in my new HIDs, had everything done hooked up and working.
Then I wanted to run my fogs with just my parking lights, so I did the mod where you run a wire from the tail light relay to the fog light fuse. I used a jumper wire just to see how it'd look because it's all I had on me, I was going to wire in a fuse after I saw the appearance. Well that was obviously a terrible idea, and I must have shorted something out because now my headlight switch doesn't turn on anything, parking lights, tail lights, fog lights, or head lights. And my Hi-beams don't stay on.
I know the headlights work because I can put the headlight switch on a half click back (as if you were flashing your brights) and everything comes on.
I volt tested all the fuses everywhere, and everything is good
I switched the relays in the fuse box around, nothing helped.
I looked in the back of the fuse box for burnt wires, nothing
I looked behind the headlight switch for burnt wires, nothing.
Any more ideas or trouble shooting how to fix the problem?
Could I have killed that switch?
Happened to me once, headlights got stuck on though, I had to pull the battery post and wait for the relays to reset. not really sure what caused it or how to do a quick fix
If you wanted to run to fog lights with the parking lights.
Why didn't you just tap them into the parking light wires?
I would try and pull the battery for about 5 minutes.
Like mentioned above.
Since you just jumped it out, you may have shorted out the relay.
I would get a new relay, if the battery disconnect doesn't work.
I saw a youtube video on the fog mod and it seemed super simple.
And I don't think bad relay is an option because I switched around the relays
I'll try the battery thing.
Took the ground off the battery for about 5 minutes, and put it back on, nothing still.
My temp fix is running the 2 wires off the fuse box directly to the battery with a fuse in between and a toggle switch, but this isn't ideal more trouble shooting would be appreciated.
