head to exhaust manifold bolts busted please help
91BlackLaser said:
What is a good upgrade for exhaust manifold studs or is there one?
They make stainless steel ones. I think slowboy sells them. I've heard that they work pretty good.
Well I got one of them out , 2 other studs I broke a reverse bit into , son of a...................
so I gave up and bolted my new 14b turbo I got from the junk yard.
Before when I had my other turbo (the bad turbo) my engine would sound like a weedwhacker past 4000, figured it was just my bad turbo.
Now I put on the 14b I bought from a junk yard, boosts just fine to 10 pounds but it still sounds like a weed whacker past 4000. I boost just fine to 10 pounds plus I pull 20 inches of vaccum at idel when warm so I figure there must be a vaccum leak between the turbo and the MAS, would that be a correct assumption?
