Head Gasket for block bored .020 over?
Vtec_Killer
227
Mar 5, 2005
Muncy, Pennsylvania
Im rebuilding a 6 bolt for my car. The block is being bored .020 over and my question is can I get away with using a regular head gasket or do I have to use one that is for a block that was bored out? Is there enough clearance for it to fit or will the gasket cover some of the cylinder? Im having trouble finding one for a .020 bore, so a site or some advice would be appreciated. Thanks.
Cometic makes gaskets for overbored blocks. If you end up using the cometic or any other msl gasket, make sure the cylinder head and block are machined with the proper finish or it will leak.
