Resolved Head Bolt / Stud Fastening pattern
PeterEvo
Nov 7, 2009
Rotterdam, Europe
I read a few different opinions on what fastening sequence should be used when fastening the 10 headbolts of a 4G63. This week I will put the cilinderhead on my block again with new ARP's and I am curious what is seen as the best procedure.
Solution
According to the FSM:
<-----Camshaft sprocket side
..8 6 1 3 9
10 4 2 5 7
Tighten in 2 to 3 steps. I hand tightened them all in sequence then did 20,50,80 with ARP moly lube, which gives more accurate torque readings then 30wt oil. Retorque after 5 heat cycles.
Yeah go by the manual if you have one or buy yourself a haynes manual. That should give you all the info you need.
You should start from the inside out in a criss cross pattern. And follow the torquing procedure from ARP in three step.
..8 6 1 3 9
10 4 2 5 7
Solution
Make sure you don't drench the studs in the lube or oil, whatever you're using, because it will drip down to the bottom, creating a pocket and youre torque spec will be off.
  • Wanted 1g Harness
    Wtb 1gb fuse box harness
    • 92AWDHX40
  • For sale 2g 2G Water Pipe
  • For sale 2g Clean title
    • FirstTimeDSM
