Having serious problems, where to take it?
Spoolio
730
10
Sep 3, 2003
Port Charlotte, Florida
ok, im fed up , my god damn car is leaking oil now, probably from the oil filter, looks like thats where its comming from, my car has a huge boost leak or something, cause it just boggs down and doesnt move when i hit boost, and i was listening to the motor, for some reason i hear something spinning around in the head or in the block , sounds like a bearing is fukin about to break or something, idk, i thought something was wrong cause my head was ticking, but my friend told me its most likely the injectors?, idk something just doesnt sound right in the motor, anyone got any good recommendations for a shop in northern nj? or central?
I don't know where Fair Lawn is in NJ, but if you are close to the PA border you might consider Slow Boy Racing. If you are closer to Maryland you might want to look into Extreme Motorsports.
THose are the only 2 specialty DSM shops that I know of even close to NJ.
I had that Problem before.....but it was because i let someone change my oil when i broke my arm.....won't do that again! Anyway it leaked from the filter because they tightened it to much and blew the seal! almost blew the engine!
Im with him have SLOWBoy check it out it could be somthing serious! They are great
    • george bromwell
    • pma1123
    • Sdcryan1
