egen223
- 0
- Jun 9, 2012
Westminster,
California
hi the situation is i just swapped a 14b td05 MIH turbo in my 1996 eclipse gst
i checked for the leak and everything was fine
but the car choke at idle and stall
when i pull the maf sensor out it idle normally but i can't go anywhere
so please if somone have done the turbo swap
what should i do next? i'm kinda stuck here
please reply i really do appriciate it
i'm using stock injector stock ecu stock fuel pump
upgrades are fmic, type s bov, and 3" catback exhaust
) and speed density it wont read the same and you are less prone to fuel cut
