Having Idle Problems
94-eclipse
Nov 24, 2010
Rockford, Illinois
When I first start it in the morning it wont idle it just dies unless I hold gas then when it warms up after bout 15 mind of runing it idles just fine.
there is not enough information here for us to be able to even begin to diagnose the issue. If you could provide more information and detail as to what you mean by "won't idle when cold". Does it surge, does it not want to run, etc. The more information you give us the faster and better our responses will be! :thumb:
thats odd my car idles higher when its cold... u can allways turn ## idle screw up, if it dont idle tho u usually have a vacuum leak
on top of the throttle body is a screw turn it clock wise about half turn that should solve that problem for ya .... i had the same problem
