newtodsm's
- 142
- 1
- Jul 9, 2009
waterford,
Michigan
i have a 96 talon with a 92 6 bolt turbo swap. i still have the 2g transmission. here is my problem. i think it is in limp mide but i cannot get any codes to come up. i just pulled the tcu out and i saw no bad spots. the car take offin second or third gear. as soon as you put it in drive and give it gas it takes off vary slow. but it doesnt do it in reverse. is this a sign of limp mode? my check engine light is on with the code for my tps sensor. i am not sure if this will cause limp mode or not. also i have a crack in my exhaust right before the flex pipe. could this cause any problems? i have ordered a new one from punishment but it hasnt came yet. any help would be great thanks
