haveing idleing issues
lou schmouder
271
Jun 17, 2008
dalton, Georgia
My car is dies upon cold start. Isc works fine fpr is at 37.5 reading 12-13 on wide band . Does fine after I crank it a few time and it gets warm. Any ideas???? Also no boost leak and rebuilt tb..
gm maf. Good compression across the board. Yes aftermarket fpr. Its not once or twic I have to crank it 10-15 time till it hits about 150 then its fine after that. New plugs also. after its warm no issues at all
If the sensor is bad it will send
the ECU a negative signal then the ECU will dump
craploads of fuel and the car will
either have a very hard time
starting or won't start at all.
In the first post you stated your WB reading of 12-13 which is rather rich.
Check for loose wires or vacuum hoses which may have leaks or worn out.You may want to check your battery. It should have at least 12.7v to get better starts. You may also want to try to jump start the car by connecting it to an idling car with a jumper cable. If it starts right away it may be a weak battery .If the problem still persist it may be a weak starter since it is harder to start a car in the morning. Other than that it could be a weak fuel pump
