Idleing problems
hubz91talontsi
1,120
5
Jul 30, 2007
bentleyville, Pennsylvania
My car is just been having numbers of problems over the past month. When i push the clutch in the car idles very rough. Somethings it ever stalls. The car has has a hard time starting up in the cold mornings im starting to believe that my alterntor is about to go. My o2 sensors are bad. Id like to hear what you guys have to say. Thanks again
Why dont you take it to autozone and they will tell you if your alternator needs replacing and why your there you can buy o2 sensors because if your o2's are bad then thats why your car is running so bad.
Are there any check engine lights on at all? Thinking and knowing are two completely different things. Go to autozone if you have a check engine light on and they can help you out. Good luck. report back with what you found.
