Have to push clutch right to the floor just to shift...
nastynas
69
May 19, 2004
Thunder Bay,
Just to shift gears, I have to push my clutch in as far as it can go. Otherwise, it just doesn't catch. Do I need to replace the clutch, or is there a way I can get around this problem?? Also, my tranny seems to almost always grind while downshifting from 3rd to 2nd, no matter what I do.
My friend had a similar problem with his 240sx, and his mechanic found out that he needed a new master and/or slave clutch cylinder (can't remember which one if it was both)
No, I havn't checked the fluid or anything. To tell you the truth, I'm not really sure how to check for air in the lines.
-There're too many thing to list because you don't even know how to bleed the line, your best bed is to get a service manual or a factory service manual on cdrom .
-Check for leak along the clutch line from end to end, then bleed the line, if still doesn't work, try adjusting the master cylinder, if still doesn't work, try shimming the shift fork's pivot ball.
http://mywebpages.comcast.net/njdsm2/clutch.html
http://www.roadraceengineering.com/clutchandflywheeltech.htm
  • For sale 4G63 NEW Stop Tech Drilled And Slotted Rotors
    New Stop Tech Drilled & Slotted Rotors $70 + shipping and paypal fees* FITS * Eclipse GST...
  • For sale 2g 2G GSX/GST Manual Transmission Steel & Poly Mount
    2G GSX/GST Manual Transmission Mount (Steel & Poly) $45 + shipping and paypal feesYou must be...
    • sanmantsi72
    • El_marto
  • For sale 1G DSM 4G63 PARTS
    • The_Partout_Spot
