clutch to the floor :(
Jorge50505
40
Apr 28, 2009
Corpus Christi, Texas
so the past few days whenever i get in my dsm the clutch is at the floor with no resistance, but i can barely shift into any gear with the clutch to the floor.
someone mentioned to me to get a new clutch line and they directed me towards the one extreme psi sells
EXTREME PSI : Your #1 Source for In Stock Performance Parts - Extreme PSI Complete Clutch Line (Slave to Master Cyl.): Mitsubishi Eclipse 95-99
my question is should i buy this or should i just check the slave master first????
help me :confused:
your going to have to change your slave first then master most will change both since the other tends to fail during the same time. you dont have to upgrade the line. so try the slave first and then master and .. bleed .. bleed bleed. until its super stiff!!!
I had the same problem with my motorcycle brakes (a little scary when you find that out on the road) bled them nice and good and it was fixed. I'd start with bleeding the clutch (simplest fix) and work your way up to the bigger and more complex fixes if the former doesn't fix it.
check ## fluid level top it off. and u may want to bleed the system just to make sure. then try it out
