Have some questions... stuck with this on magnus installation...please help
highintenzity4
221
Apr 30, 2004
Mission, Texas
Do I eliminate vaccuum line from charcoal canister to fuel tank, it also has a small valve with an arrow pointing towards the canister?? Advice would be appreciated... Thanks.
You can do which you want with it T into it and keep the vac or just loose it any way you want really. I run no charcoal cannister at all :shhh:
Disconnect everything so all you're left with is a line going to te bov, boost controller, wastegate, boost guage, brake booster, and fpr. All other lines can get eliminated.
