Jeff99GS
- 1,869
- 17
- Jun 27, 2006
Cleveland,
Ohio
I'm looking at buying a Holset turbo off a 2008 Dodge Ram 6.7 Diesel. It has an electronic wastegate on it.
Does anyone know of a way to connect this with some kind of pressure switch in the IC pipe?
I was thinking if you had an adjustable pressure switch set to 20 psi that was tapped into the Intercooler pipe it could be used to open the electronic wastegate at 20 psi and it should hold perfect with NO creeps or SPIKES!
What are your guys thoughts on this? Anyone tried anything like that??
