Harness
DsmDave95
105
Nov 19, 2006
Long Island, New York
Ok since my cars down for the winter, The take down has begun im takin out a lot of things. One thing i want to do is clean up the harness get rid of all misceallaneous wiring that i dont need, or im not using. for the guys who have done the ABS delete what did you do with all of those wires, also wires for fog lights and extra wires around the bay. if you have any helpful pictures you wanna post please do so.
thanks in advance,
-Dave
Just be carefull what you cut. When i went full stand alone i cut a few things that i shouldn't have. There was a test connector for teh ignition that i cut along with teh resistor pack wires and i had to go through, find them and patch tehm back together to get the car running again. LEave any and all "test plugs" in there, just tuck them away. The reason i had these troubles, is that i ran my stand alone through teh stock harness from inside teh car, and although i didn't need teh resistor pack, it had to be soldered to a "closed loop" for the injectors to get their power. Then the ignition test port had 2 wired that joined together at the plug adn without them both hooked up onlly half of my coils were firing. I"ll think a bit harder before the next time i'm under the hood with a beer in one hand and wire snips in the other LOL.
Just be carefull what you eliminate, especially on a stock ECU and harness.
