hard to shift gears clutch prob
talongod
274
Nov 24, 2002
Mayfield Hts., Ohio
Ok so my slave cylinder was leaking and i couldnt shift at all so i got that fixed and then my clutch was sticking to floor so i got the master cylinder fixed and now its hard to put into first and also shifting gears
any input plz??
it seems like the clutch is not all the way down so it almost wont go into gear but if u jam it in it will go in and also when i give it gas it seems like it goes in easier and plus its getting harder and harder to put into gear
Sounds very much like air in the system. Did you compare the bleeding method used in the article I gave you with how you bled it? If you even bled it that is.
yes of course i bled it, i think it might be the clutch itself something inside is blocking it
